Is anyone else getting an error when trying to save a snapshot of an easy chart using right click → save as?
The screenshot is attached below, and here is the trace:
java.lang.NoClassDefFoundError: org/jfree/chart/imagemap/OverLIBToolTipTagFragmentGenerator
at org.jfree.chart.ChartPanel.doSaveAs(ChartPanel.java:2233)
at com.inductiveautomation.factorypmi.application.components.chart.PMIChartPanel.doSaveAs(PMIChartPanel.java:113)
at org.jfree.chart.ChartPanel.actionPerformed(ChartPanel.java:1425)
at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.actionPerformed(PMILineChartPanel.java:599)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
Caused by: java.lang.ClassNotFoundException: org.jfree.chart.imagemap.OverLIBToolTipTagFragmentGenerator
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at com.sun.jnlp.JNLPClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 31 more
