Hi
In Ignition 7.6 (or 7.7 if this feature has been added), is there a way to display the Easy Chart customizer window, exactly as it is in the designer, from the runtime?
My use-case is this:
I want to have an “edit” button on a window containing an Easy Chart, which then allows users with the appropriate privileges to graphically alter all parameters of the chart (exactly the way the customizer does), and then a save button which stores the chart configuration datasets back into a SQL table for later recall as necessary. These users are familiar enough to use the customizer, but do not have access to the Ignition Designer.
I realize all the configuration data for the Easy Chart is stored in the configuration datasets, and I have these bound to SQL tables, but to edit the configuration in a user-friendly manner (i.e. with a GUI) means either 1) using the customizer as it is obviously already there, or 2) re-inventing the customizer for run-time use. Clearly, I would like to avoid having to re-invent the wheel!
I apologize if I am missing something glaringly obvious, but I can’t see a way of “calling” the customizer during runtime.
Regards
