Easy Chart Save
I have an ignition edge gateway running on Linux and am using Vision. If I open my trending page which uses Easy Chart using the client on the gateway, the save button works just fine. However, if I use a client on a machine running windows, it locks up the client. I have to use taskmanager to "End task" of the Zulu Platform. Is there a setting that I'm missing of is this just not possible?
Should work the same everywhere. Possible bug?
Running 8.1.36 on the gateway and using the same for my Vision client on the windows PC. The maximize and print buttons work just fine, but for whatever reason the save button locks up my client. I guess I'll reach out to tech support.
What's the client max memory set to?
256M max
I increased to 2048 had the same issue
I'll apologize here. It looks like the window was hidden behind my way too many windows open.
