I have two groups in easy chart with multiple parameters. In default, all options are unchecked. For eg: If i click on more than 1 parameter, data with lines are displayed. But when i especially click on Line speed, no line is showing, instead only the value is displayed.
Please find the pics for reference.
I needed line speed to be displayed when i clicked only on this option.
What might be the issue?
So I see your Line Speed is constant at 200, is it supposed to be a static value? Also how do you have the range of the chart setup? As the value of Line Speed could be 201 and it doesn’t show up on the chart. Maybe you can try setting the range for the chart to 100-300 and see if the Line Speed shows up?
Yes sometimes it may be static. And the range of the chart is auto.
It is working now,
What i did was., I have deleted the chart and created a new one &binded the paths.
