Hello,
I have a project where I use easy chart and plot my historian tags.
The easy chart are performing in a way that I do not understand. One line is smooth and the other is edgy, even though the two tags are set up exactly equal in all parameters.
When I remove the smooth line from the plot, the edgy line becomes smooth, but when I add the previous smooth line, the previous edgy line, becomes edgy again.
Can someone explain why this is happening, and what I can do to only have smooth lines?
You’d have to do something in the configureChart customization script to directly adjust the JFreeChart objects. Not trivial, unfortunately, and I don’t have an example handy. /:
I am not using any pen configuration. I am using a tag tree that I drag and drop onto the easy chart. My tags are then historian enabled, and used in easy chart.
Did you end up getting this fixed with support? I'm having a similar issue right now.
For me it almost seemed like you only got so many types of aggregations before the engine just kinda gives up, but your problem only had 2 pens, both with the same aggregation. The only similarity between our situations is the way the tag history is set up (minus storage provider ofc)
