Which property do i have set wrong? The data only exists on change, ie the setpoint was changed. When i populate a chart with this data the lines between the data points are diagonal instead of straight lines.
Have you tried setting your pen style to digital?
i set it to digital, then set raw mode for the chart. that was the trick. Thanks.
