Easy Chart Tag Browser
Hi Gents,
I have enabled history for some tags and I would like to view them in an Easy Chart.
To add a pen to the Easy Chart, I need to choose a Tag from the Tag Browser. But the tag that I want is not in the tag browser ( even though history has been enabled for it).
How do I add the tags to the Tag Browser? I was able to add a few of them last time around but now, I can't figure out how I did it then!
Thank you all.
Check your tag browser's filter method. There's probably something there that is filtering out your new tag.
Thanks pturmel.
It was a case of history enabled tags, already retired, but still showing up in the Tag Browser. This has been happening with some folders and tags that I had to delete or move around. Had to play around the sqlth_te and sql_data. It's good now.
