Hey guys,
I found a couple of problems with adding tags and adding properties into the cell update property binding.
I was creating a easy chart window today (I haven’t done it for a few versions so I don’t know when this happened) and when I clicked on the tag icon to add a tag for a pen I was presented with a blank screen. If I type in the tag path manually it works but I can’t select it from the tag selector:
The other problem I found was when I tried to edit the tag names with the cell update property to make it dynamic. I added the row but the tag path did not populate down into the cell update value pane, I again had to type in the address manually. Then I tried to add in the property to make it dynamic and I could select the property with the property selector but it would not put my selection into the cell update field. I had to also type in the property by hand. Everything still worked but it just made it a lot harder and more tedious.
I’m running Ignition version 7.4.2 (b953)
