Hello, I am new to ignition and wanted to know why the Tag Pens property does not appear in the property editor for the Easy Chart component. The last category is RealTime Range. I have version 7.9.2 installed.
Thank you
Thank you
Check the property filtering applied to your property editor:
‘Realtime Range’ is the last option if you’re in Standard, rather than Expert/All.
