On the Easy Chart, Why doesn’t the time axis on the bottom of the chart match the time thats being requested from the timedate picker portion of the Easy Chart.
For example, the datepicker shows:
7/17/07 7:01 AM - 7/17/07 7:05 PM
but the bottom of the chart shows
Jul 17 2007
The left edge is approximatle 9:45 am and the right edge is approx 10:45 pm.
The X axis of the easy chart scales itself to the range of actual datapoints that it is displaying, with a slight margin on either side. So, if your data starts at 9:45, thats where the x-axis will start, even though you requested to show everything from 7:01 ( there is no data between 7:01 and 9:45). I’m not sure why the right edge of your axis is beyond the requested range - I’d have to see that.
We’re thinking of making the range of the x-axis not autorange (as an option). I’ll count this as a vote for that feature.
I think you’re talking about a separate (and known) issue, which is that sometimes when you first bring up a window, the date range component doesn’t appropriately initialize its initial range. This is fixed, and will be in 2.1.5, which will be released as soon as we get an administrative issue resolved regarding our code signing certificate.
