Is it possible in ignition vision to change Y axis label orientation of easy chart?
I'd like it to be horizontal rather than vertical since they run into each other when I get a lot of subplots:
Thank you!
This can be done with scripting using the configureChart extension function.
Example:
def configureChart(self, chart):
# Needed to convert the more intuitive degrees into the required radians
# ...This could probably also be done close enough without the import using angle * (3.14/180)
from java.lang import Math
# Check to see if subplots are being used (CombinedDomainXYPlot)
if hasattr(chart.plot, 'subplots'):
# Iterate through all of the range axes for each subplot and set the label angle to 45 degrees
for plot in chart.plot.subplots:
for axis in xrange(plot.rangeAxisCount):
plot.getRangeAxis(axis).setLabelAngle(Math.toRadians(45))
else: # (AutoAnnotateXYPlot)
# Iterate through each range axis of the default ploy rotate all labels 45 degrees
# ...if there are any axis on the right side, the angle will have to be 225 [45 + 180] to orientate right side up
for axis in xrange(chart.plot.rangeAxisCount):
chart.plot.getRangeAxis(axis).setLabelAngle(Math.toRadians(45))
Result:
Edit: The original code assumed the implementation of subplots based upon the OP's picture. Updated the code, so it will work whether or not subplots are being used.
Works great, thanks ![]()
