I’m having an odd issue with the trends cutting of the newest data. The odd part is that when i change the unit count of the trend it will display the data that is missing(changing it from a 24 hour trend to say a 23 hour trend, pictures attached). I’ve tried messing around with the Tag History settings of the trends but it seems to fix it in the designer but not the client application or it fixes it on one trend but not another. Any help would be much appreciated.
Other info:
Ignition Version: 7.8.1
Tag History Resolution: Chart Width
Allow Tag History Interpolation: True
Validate Scan Class Executions: True
Ignore Bad Quality Data: False
Bypass Tag History Cache: False
Also, this problems exist in the version 7.7.8.
The problem occurs less frequently with the following settings:
“Tag History Resolution Mode” = “Chart Width”
“Tag History Resolution” = 0
So sorry i haven't checked this forum. I assumed i would get an email when a response was posted.
all my trends were set up using the easy chart configuration, not the property binding. I tried to look for it outside of that window but couldn't find anything.
[quote="HooK'a"]Also, this problems exist in the version 7.7.8.
"Tag History Resolution Mode" = "Chart Width"
"Tag History Resolution" = 0[/quote]
I have a good portion of my trend using those settings. It seemed to help in the designer but not when running the client.
