EasyChart - find Chart Configuration / TagPens - dataset on Ignition 8.0.12
Hi
I created a EasyChart and I need to change the pens dinamically.
I defined Tag History Pens and, on Tag Path I could only catch fixed elements from the DataBase.
I look forward for help on manual. it said that we could change the pen from a variable:
https://docs.inductiveautomation.com/display/DOC79/Indirect+Easy+Chart
I attach the picture:
The problem is that I couldn’t find this : Chart Configuration on my chart (Ignition 8.0.12)
Please, any help will be apreciated.
Thanks,
Guillem
Make sure your property editor filter is set to all.
Many thanks Irose,
Other question, it is possible to know the value at exactly moment with this easychart?¿
I mean, put the cursor on a position of the trend and show or read the value of the variable.
Thanks in advance,
Guillem
Sure, from the right click menu choose the mode to be either Mark or X-Trace.
See the manual for more information
OK, Many thanks Irose!!!
