Hello, I am getting connection lost error from our Eaton power meter. The meter was firmware updated to 2.1.37 which changed the interface to HTML5 I believe. I’m using a TCP connection. It is losing the connection at 59 seconds. reconnects then lost in 59 seconds.
The error message is
java.io.IOException: End of stream reached.
at com.inductiveautomation.iosession.socket.AsyncSocketIOSession.run(AsyncSocketIOSession.java:74)
I am fairly certain it is an ignition issue. I can connect directly to the meter and all looks good. Any ideas on what I am missing.
