I’ve been having issue to link Ecostruxure OPC UA with Ignition, I’ve been able to trust certificate and add the ignition Cert to Ecostruxure but now I’m facing this error :
io.netty.handler.codec.DecoderException: UaException: status=Bad_CertificateUseNotAllowed, message=required KeyUsage ‘keyEncipherment’ not found
The ignition certificate seem to provide Key Encipherment
But the ecoxstructure does not seem to provide it:
Anyone has successfully connected Ecostruxure to Ignition ?
I think you meant to say they don’t provide it, right?
You should report this to EcoStruxure and work with them to get a valid OPC UA certificate generated. In the meantime, though, there should be an advanced setting on the OPC UA connection in Ignition to disable certificate validation.
