Hello everyone,
we have a problem on ignition edge 8.1.25.
every time we apply a script "with value change" we receive the following error.
Error compiling event script for event id 'valueChanged'.
java.lang.Exception: Scripting is not available for this platform edition.
Welcome!
Edge requires the compute add on license for scripting. I thought that was only gateway scripts, is this a value changed script at the gateway level or directly on a tag?
it doesn't matter whatever script we try to configure, either on gateway or directly on a tag
Directly on a tag is also gateway scope, and requires the compute plugin.
which version and after is this changed?
on 8.1.1 it works without a problem.
On Edge? And not in trial mode?
{ Edge restrictions on gateway scripting go back to the very first versions of Edge. }
Yes on edge and not trial mode.
Then look at that installation's license for the compute plugin.
