Hello,
I have a gateway network set up, 1 edge node with a redundant node, attempting to send tag data back to Standard Ignition gateway historian. The issue is I can't get the historian on my standard gateway to log any data from the edge node.
Things I have checked already.
*I went through security policy and ensured that history provider access was set up correctly.
*I'm using a core historian module on the standard gateway.
*Ive ensured comms are good to all devices.
*Running Version 8.34 on all nodes and gateway
The pic below is from the edge node.
Pics below are from Standard Gateway
How do you have sync services set up?
Did you follow this video?
Yeah, that's how I set it up.
Getting this error code now.
If all else fails, you may want to reach out to our support team and they can do a deeper dive. I think something still might not be configured to match exactly. In the logs, I see it's looking for 'Main Standard' but in the security zone image, it shows 'main'. The service security(Edge Sync settings page) needs to match exactly what shows for the standard system.
Yeah, I was playing around with it some more and was able to get it working. You were correct, I had the wrong security zone settings.
