Edge Docker DB file
i am running IgnitionEdge 8.3 , i would like to know the local db folder to mounted outside the container , is it /ignition/data/metricsdb ?
If you're running Ignition on Docker, you'll typically persist /usr/local/bin/ignition/data as a volume.
i mean , getting Edge Historian backup file , incase of reacreat the image again and we need the last historian backup
i would like to get the edge local db backup file
