Hello,
I am trying to start an 8.0.16 edge gateway and I am getting the following output in the wrapper.log file:
STATUS | wrapper | 2021/03/11 14:08:30 | --> Wrapper Started as Daemon
STATUS | wrapper | 2021/03/11 14:08:30 | Java Service Wrapper Standard Edition 32-bit 3.5.42
STATUS | wrapper | 2021/03/11 14:08:30 | Copyright © 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2021/03/11 14:08:30 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2021/03/11 14:08:30 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2021/03/11 14:08:32 | Launching a JVM…
INFO | jvm 1 | 2021/03/11 14:08:34 | WrapperManager: Initializing…
INFO | jvm 1 | 2021/03/11 14:08:45 | 14:08:45,423 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2021/03/11 14:08:45 | 14:08:45,496 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2021/03/11 14:08:45 | 14:08:45,570 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2021/03/11 14:08:45 | 14:08:45,927 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2021/03/11 14:08:46 | 14:08:46,049 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,291 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@1e9eae2 - Driver name=SQLite JDBC
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,292 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@1e9eae2 - Driver version=3.23.1
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,292 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@1e9eae2 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,369 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,416 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,418 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,419 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,429 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,433 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,435 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,444 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,444 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,445 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,455 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,466 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,474 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,475 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2021/03/11 14:08:47 | 14:08:47,489 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@6b5c2a - Registering current configuration as safe fallback point
INFO | jvm 1 | 2021/03/11 14:08:48 | E [IgnitionGateway ] [06:08:48]: Error initializing web manager:
INFO | jvm 1 | 2021/03/11 14:08:48 | java.lang.IllegalStateException: Could not read catapult properties.
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.readGatewayProperties(WebResourceManagerImpl.java:430)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.(WebResourceManagerImpl.java:106)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.(IgnitionGateway.java:483)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:273)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/java.lang.reflect.Method.invoke(Method.java:566)
INFO | jvm 1 | 2021/03/11 14:08:48 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/java.lang.Thread.run(Thread.java:834)
INFO | jvm 1 | 2021/03/11 14:08:48 | Caused by: java.util.InvalidPropertiesFormatException: jdk.internal.org.xml.sax.SAXParseException;
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.PropertiesDefaultHandler.load(PropertiesDefaultHandler.java:85)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/java.util.Properties.loadFromXML(Properties.java:983)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.catapult.util.PersistentProperties.tryLoad(PersistentProperties.java:114)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.catapult.util.PersistentProperties.(PersistentProperties.java:73)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.catapult.util.PersistentProperties.(PersistentProperties.java:54)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.catapult.util.PersistentProperties.(PersistentProperties.java:43)
INFO | jvm 1 | 2021/03/11 14:08:48 | at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.readGatewayProperties(WebResourceManagerImpl.java:428)
INFO | jvm 1 | 2021/03/11 14:08:48 | … 10 common frames omitted
INFO | jvm 1 | 2021/03/11 14:08:48 | Caused by: jdk.internal.org.xml.sax.SAXParseException:
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.impl.ParserSAX.panic(ParserSAX.java:652)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.impl.Parser.step(Parser.java:494)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.impl.ParserSAX.parse(ParserSAX.java:436)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.impl.ParserSAX.parse(ParserSAX.java:411)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.impl.ParserSAX.parse(ParserSAX.java:374)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.impl.SAXParserImpl.parse(SAXParserImpl.java:97)
INFO | jvm 1 | 2021/03/11 14:08:48 | at java.base/jdk.internal.util.xml.PropertiesDefaultHandler.load(PropertiesDefaultHandler.java:83)
INFO | jvm 1 | 2021/03/11 14:08:48 | … 16 common frames omitted
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp:
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: Encountered an error running main:
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: java.lang.NullPointerException
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at com.inductiveautomation.ignition.gateway.IgnitionGateway.start(IgnitionGateway.java:538)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:275)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at java.base/java.lang.reflect.Method.invoke(Method.java:566)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO | jvm 1 | 2021/03/11 14:08:48 | WrapperSimpleApp Error: at java.base/java.lang.Thread.run(Thread.java:834)
STATUS | wrapper | 2021/03/11 14:08:50 | <-- Wrapper Stopped
I thought maybe it was a permissions problem somewhere but I am pretty certain I have updated permissions for all needed files/folders now and I am still seeing it.
