Good morning. I am attempting to install Ignition Edge on a laptop that has never had Ignition installed on it. I’m following the instructions from the manual - https://docs.inductiveautomation.com/display/DOC80/Installing+Edge
After downloading and unzipping the files, I double-click install-ignition.bat. Regardless of whether I double-click it or load it from the cmd (running at the Adminstrator level) it always freezes at the following, and nothing further happens:
For kicks and grins, double-clicking on start-ignition.bat gives the exact same response.
Wrapper log contents contents below (interestingly enough, I’ve recently started getting the exact same error on a separate company laptop running Ignition Gateway 8.0: “Unable to execute Java command. The system cannot find the file specified. (0x2)”).
STATUS | wrapperm | 2020/01/08 10:32:56 | Ignition Gateway service installed.
STATUS | wrapperm | 2020/01/08 10:34:39 | Starting the Ignition Gateway service…
STATUS | wrapper | 2020/01/08 10:34:39 | → Wrapper Started as Service
STATUS | wrapper | 2020/01/08 10:34:39 | Java Service Wrapper Standard Edition 64-bit 3.5.35
STATUS | wrapper | 2020/01/08 10:34:39 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2020/01/08 10:34:39 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2020/01/08 10:34:39 | Licensed to Inductive Automation for Inductive Automation
ERROR | wrapper | 2020/01/08 10:34:39 | Unable to execute Java command. The system cannot find the file specified. (0x2)
ERROR | wrapper | 2020/01/08 10:34:39 | (null)
STATUS | wrapper | 2020/01/08 10:34:39 | ← Wrapper Stopped
ERROR | wrapperm | 2020/01/08 10:34:41 | The Ignition Gateway service was launched, but failed to start.
ERROR | wrapperm | 2020/01/08 10:34:41 | Please check the log file for more information: C:\Users\mattb\Desktop\Ignition-Edge-windows-64-8.0.7\logs\wrapper.log
STATUS | wrapper | 2020/01/08 12:12:44 | → Wrapper Started as Service
STATUS | wrapper | 2020/01/08 12:12:45 | Java Service Wrapper Standard Edition 64-bit 3.5.35
STATUS | wrapper | 2020/01/08 12:12:45 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2020/01/08 12:12:45 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2020/01/08 12:12:45 | Licensed to Inductive Automation for Inductive Automation
ERROR | wrapper | 2020/01/08 12:12:45 | Unable to execute Java command. The system cannot find the file specified. (0x2)
ERROR | wrapper | 2020/01/08 12:12:45 | (null)
STATUS | wrapper | 2020/01/08 12:12:45 | ← Wrapper Stopped
Any thoughts on what I’m missing? Not sure what direction to head next here.
Thanks!
