Edge to Edge Data best Practice
Anyone have any learning for an Edge to Edge Control data exchange ?
Assuming secured IP comms between edge to edge and edge to central broker is available,
I can see 2 main options ,
Option 1) route everything through the broker.
Option 2) create a edge to edge connection,
My question is what would be best practice for the Option 2) edge to edge connection? (using ignition edge ideally)
You can create a Gateway to Gateway connection but it doesnt seem to have any use, as you can create a remote tag provider, ideally i want to use MQTT Edge to Edge so is the only option to use the MQTT Distributor Module in one edge device and connect the other edge devices to it.
in
Answering my Own Question this is what i have come up with.
