We have a full version of Ignition that is used to run several processes. We have Ignition Edge at the site as well. We have created an OPC UA connection from Edge to Ignition successfully, and can view some tags. However, not all of them. It appears to be dataset tags that are not visible. Any ideas/suggestions?
Dataset tags aren’t available over OPC UA.
Use a remote tag provider instead?
So I should have the Full version set up a remote tag provider targeting the Edge gateway's 'edge' provider, and then write tags that way? I don't see a way to set up a remote tag provider from Edge, which would definitely be preferred.
