Hello,
I have an Opto Groov EPIC as the edge device. It runs a licensed Ignition Edge V7.9.12. Now that an upgrade to Ignition Edge V8.0.12 is required:
Edge gateway is accessible from a browser with the URL having the IP of Groov EPIC device. Should we run the upgrade file on any PC that have network access to the edge device?
If I have Ignition Gateway configured in the same PC, should I use the same installation folder? (to run stop.ignition.bat, remove lib as described in the upgrade procedure)
Would this upgrade have an impact on the license?
Any help is greatly appreciated.
