I was given some UDTs from a distributed gateway system to use in a new Edge stand alone application.
Trying to use them, but not working like I had hoped. Diagnostics show several items “Bad_NotFound”. Verified that the PLC UDT matches the Ignition UDT tag. I’m guessing that the path properties of the Ignition object have a syntax issue?
I know the server name (aoiServer) and connection path (aoiPath) work for simple BOOL and INT tags.
Any suggestions?
Thanks.
