bellm
1
I am trying to edit a tables attributes with a button press script. But am getting the following error:
File "event:mousePressed", line 2, in
TypeError: setValue(): 1st arg can't be coerced to com.inductiveautomation.ignition.common.Dataset
Ignition v7.9.9 (b2018081621)
Java: Oracle Corporation 1.8.0_191
Here is the code I am trying to use:
table = event.source.parent.getComponent('Table').columnAttributesData
newData = system.dataset.setValue(table.data, 1, 'editable', 1)
table.data = newData
Is it possible to edit the attributes dataset?
Take the .data off of your setValue call.
You are assigning “table” to the column attribute dataset the line above it.
bellm
3
I tried that but when I do that I get the following
File "event:mousePressed", line 3, in
TypeError: can't convert Dataset [6R ? 30C] to [[Ljava.lang.Object;
Take a look at this script. If you analyze it you should be able to see the places where your script went off track.
columnData = table.columnAttributesData
newData = system.dataset.setValue(columnData, 1, 'editable', 1)
table.columnAttributesData = newData
