Edit Contact info for existing users
I have the following code for adding contact info when creating a new user…
contactInfo = {"email":self.getSibling("txtEmail").props.text}
userToChange.addContactInfo(contactInfo)
How would you be able to change this so it can edit existing contact info instead of adding new info?
The User object appears to have a .setContactInfo() method that allows you to rewrite it’s internal contact info. However, it expects a list of ContactInfo typed objects which isn’t super friendly or obvious. However, code like this should work for ya:
from com.inductiveautomation.ignition.common.user import ContactInfo
contactInfo = ContactInfo('email','test@test.com')
user = system.user.getUser('default','admin')
user.setContactInfo([contactInfo])
system.user.editUser('default',user)
Also, if you retrieve a ContactInfo from an existing user, you can setValue or setContactType to modify it into a different object - then reassign it to the user and commit the edited user.
Thanks, that worked out.
