Inductive Automation Forum
Edit Power Table to Choose multiple rows by script
Ignition
ignition80
yifeiliu08
September 4, 2020, 8:28am
1
870×903 63 KB
I use SQL to binding a power table, the first column is boolean I use 0 as default
I want to have a script if i click that rows(as the blue highlight) , it will invert the value , for example 0–1 , 1–0
JordanCClark
September 4, 2020, 10:39am
2
Make sure your ‘Send’ column is editable, using the table customizer
The default onEdited script will work, if you uncomment the line.
yifeiliu08
September 4, 2020, 2:23pm
3
1126×860 107 KB
thanks it works
Bastian_Jara
January 19, 2023, 12:38am
4
thanks a lot!
