Edit projects across Gateways?
Hi Everyone,
Still working on reworking our enterprise system with 10 projects at various locations with a hub/spoke architecture. I have cleaned up a lot of stuff and am slowly converting each spoke to version 8.1 and then finally transitioning the hub to 8.1. I have set up gateway networks between each spoke & hub and also setup remote tag provider.
My question is, can you push edits from one project to another or "link" projects through the gateway network? If I make a vision project change at a spoke can I push that edit to the Hub or do I need to do a Export/Import for individual items?
Are you using the EAM ?
Ignition Enterprise Administration Module | Manage Servers From One Location (inductiveautomation.com)
I am not, but perhaps that will answer my question. If it does I will look at purchasing the module.
Without EAM you would need to do this manually.
I believe it is what you are looking for.
