im having problems editing tag alarms
Attempt #1
i can get the tag data but once i change the value of the property it does not reflect to the tag.
(which means its not an OBJECT?)
i need an alternative to write to the tag alarm property
alarmState= system.tag.getAlarmStates(tagpath)
for tagdef in alarmState:
for prop in tagdef.getAlarmProperties():
if prop.property=="enabled":
prop.value="[.]alarms_enabled"
Attempt #2?
system.tag.editTag(tagPath=tagpath,alarmConfig={“Alarm Hi”:{“enabled”:"[.]alarms_enabled"}})
but im getting this error
do yuo have a sample how to edit the alarm on atag? the example on the web is very vague and doesnt contain much on alarms.
org.python.core.PyDictionary cannot be cast to org.python.core.PyList
required is PyDictionary supposedly but why cast it to Pylist?
PyDictionary alarmConfig - The alarm configuration for the tag.
File “event:actionPerformed”, line 3, in
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:328)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:302)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:259)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:864)
at com.inductiveautomation.factorypmi.application.script.builtin.ialabs.IALabsTagFunctions.editTagImpl(IALabsTagFunctions.java:54)
at com.inductiveautomation.ignition.common.script.builtin.ialabs.AbstractIALabsTagFunctions.editTag(AbstractIALabsTagFunctions.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: org.python.core.PyDictionary cannot be cast to org.python.core.PyList
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:428)
at org.python.core.PyObject.__call__(PyObject.java:320)
at org.python.pycode._pyx65.f$0(<event:actionPerformed>:3)
at org.python.pycode._pyx65.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:624)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy28.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: org.python.core.PyDictionary cannot be cast to org.python.core.PyList
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
… 48 more
Caused by: java.lang.ClassCastException: org.python.core.PyDictionary cannot be cast to org.python.core.PyList
at com.inductiveautomation.ignition.gateway.script.ialabs.IALabsTagFunctions.handleAlarmConfig(IALabsTagFunctions.java:360)
at com.inductiveautomation.ignition.gateway.script.ialabs.IALabsTagFunctions.__editTags(IALabsTagFunctions.java:749)
at com.inductiveautomation.ignition.gateway.script.ialabs.IALabsTagFunctions.editTagImpl(IALabsTagFunctions.java:654)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.IALabs.editTag(IALabs.java:162)
at sun.reflect.GeneratedMethodAccessor681.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:177)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:345)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:769)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1125)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1059)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:497)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:248)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:610)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:539)
at java.lang.Thread.run(Thread.java:745)
