Hello,
Is there a way to edit a tag on a power table in vision? I have marked the column in each I would like to edit values to send to PLC.
However, I cannot change the value when inputting a number.
Help is much appreciated
Hello,
How is the table getting populated?
Just a tag from PLC. I am able to change values at tag browser and send it to PLC, but not when I try to use the power table to do so.
What does this mean? A live PLC tag isn't producing a dataset for your table. Some kind of binding is in the middle.
Did you write a script to take newly edited values and write them to the tag? (That is what is required.)
