Hi, I’m trying to edit a simulator. From the instruction for both pre and post versions 8.08 it says there should be a “more” button to press with edit as being one of those options. I have no “more” button, only “edit” and that only allows me to edit the title of the document. There is also a “delete” button and that doesn’t seem to help me edit the simulator either. Thanks for any suggestions.
In Ignition 8.0.5 the programmable logic simulator is not implemented and instead some pre-made simulators are generated at the bottom of the new Devices menu. Those are the simulators you are seeing and they can’t be edited. Here is a document about them: Simulators - Deprecated Ignition Features - Ignition Documentation.
