Editing Custom Properties of Templates Through Script
Hello!
Hoping this will be a simple but having a hard time finding what I need online.
I'm trying to create a pushbutton within a template that will increment/decrement the custom property integer that I created in the template.
Here is what I tried, which worked for OPC tags and such. How can I do this same thing with custom properties in a template?
path = "event.source.parent.Clear_Numeric_Input"
value = system.tag.readBlocking(path)[0].value
if value < 2:
print("Only Recipes 1 - 99 available.")
else:
system.tag.writeBlocking(path, value - 1)
Thanks!
You wouldn't use a tag write for a custom property.
Just increment the property itself.
I am assuming Clear_Numeric_Input is the custom property name on the template?
event.source.parent.Clear_Numeric_Input=event.source.parent.Clear_Numeric_Input+1
Doy, lol I knew it would be something extremely simple. Thank you very much!
You should be able to shorten this to:
event.source.parent.Clear_Numeric_Input+=1
