I need to edit some floating point numbers for a refridge system. I would have liked to use the spinner, with a click up or down equating to +/- 0.1 deg C. It does not appear to support negative numbers however…
Then… I decided the slider control might work as well. However, it does work with negative numbers but does not appear to support deical places (0.1)…
Am I correct? Can I use these fancy controls for adjusting by +/- 0.1 setpoints?
