I have a remote provider sourced from a gateway v8.0.13 which i can not edit tags on. My local gateway is v8.0.10.
I only have a single default zone on both systems with rights given to the tag provider as read/write/edit.
The setting for the Trust remote Roles is gone, so not sure what configuration i am missing to allow the remote edit of the tags.
I am also questioning if this is a issue with the two different version of the gateways. I have an other remote provider sourced from a v8.0.10 node that i am able to edit without issue and the same configuration.
