Efficiently Parsing Large TCP Byte Array into UDT in Ignition
Dear Everyone,
I receive a TCP message as a byte array in Ignition and use a gateway tag change script to parse it into individual fields. These fields are then written to tags organized in a UDT. The parsing logic works, but it's not efficient when the message size is large (e.g., several kilobytes). Is there a better way to parse and map the byte array directly to a UDT structure?
Thank you in advance for your support!
What's inefficient about it? How are you measuring efficiency?
If you're writing each tag individually it could be slower compared to building arrays of tags and values, then at the end of parsing a message, write them all at once with a single call.
If you aren't wrapping the byte array in a java.nio.ByteBuffer setting endian order, then using its accessor methods, you are doing it wrong.
Thanks for all response,
I'm looking for a more efficient solution to parse 8192 bytes of data from a TCP driver into a UDT instance. My current method is time-consuming and hard to maintain, even without considering performance. Is there a way to define a data format like a struct first, then parse all the MessageBytes into it?
Thanks for your solution, I’ll give it a try.
You can do this with my EtherNet/IP module's Host Device driver's scripting support.
/shameless plug
Hmmm. Probably can use the module unlicensed for pure data type and structure manipulation.
It seems like it's a driver for EtherNet/IP. Is it suitable for use with the TCP Driver? Or can it be used for the purpose of creating struct data?
Yes, my EtherNet/IP driver is for EtherNet/IP. :man_shrugging:
But it installs a bunch of helpers and data type handlers in system.cip.* that could be useful to you. But first, you should try the ByteBuffer approach.
thanks for your support :slightly_smiling_face:
