Email reports returning empty PDFs
Hi all,
I'm working on sending reports via email which is working just fine. However, because of the way I had to set up the reports to be viewable in perspective I am being returned empty reports that look like this:
whereas in the perspective session I'm able to see reports that look like this:
I'm uncertain as to how to fix this but hopefully someone a little more skilled with the subtlety of perspective can help me troubleshoot this one.
Thank you,
Cam
Are there any parameters on your report that it requires to populate the report data? I would double check that when you are calling system.report.executeAndDistribute() to send the email that you are passing all needed parameters, and that parameter the keys are not misspelled.
