Embedded view auto fit
Is there a way to auto fit embedded view to delete scroll bars and increase height value like image below ?
I use nested embedded views.
Thanks.
make the containers in the views responsive (percent based)
you can change scrollbar functions with the style prop overflow (but i doubt you will need it once you changed the other view)
How Can I do views percent based ?
You can either construct the View with a responsive container type (like a Flex container), or if you’ve already constructed the View with a Coordinate layout you can switch root.props.mode from “fixed” to “percent”.
I use only Flex and Breakpoint Containers.
It seems to work with method below :
  • Root Embedded View :
  • Called View (BreakPoint) : I have Embeded Views with configuration below
  • My last called View containing the table which is configured below
The final result :
Ah, yes, if you’re using responsive containers then you just need to provide a reasonable basis for the content.
