Has anybody experienced an issue after saving in designer your embedded views will show an error that couldn't find its param properties, see image below?
I have a flex container and I'm embedding a coordinate container, I have not seen this behavior when I embed multiple flex containers into each other only in this combination. If I refresh the page in the browser or save again it loads correctly.
Saving will presumably save whatever is in the parameters in designer for the embedded view. If you're not passing those parameters on the instance of that embedded view it would change the binding.
Edit: not the binding definition, the value you're getting through the binding. Sorry, that was unclear.
Confirm you're passing a valid parameter on the instances that are getting broken. Try copying the value you're passing into the parameter to the view definition and see if there's a binding problem with that parameter.
