Embedded View
I have a Flex View with a single SVG element in the root container. The view has an object parameter called 'highlight' with a boolean member named 'enable.' One of the SVG colors is bound to view.params.highlight.enable with a Map transform to set the color according the state of the boolean.
Parent View
I have a Coordinate View with 10 embedded views all pointed at the Flex View described above. I have synced the parameters. If I manually toggle the highlight.enable boolean on various embedded views I see the following:
- Only the first embedded view I created causes any changes, the rest do not respond to toggling
- When the first embedded view is toggled, all embedded views change color
When I add logic to toggle the highlihgt.enable boolean via onPointerEnter/onPointerLeave events and launch the application, I see the same problem at runtime. I tried cycling the param's input/output state, and I have used print statements to verify that other parameters like equip id are unique when the event script is running.
I instead went with this direct binding approach and manual toggle to focus on the problem the best I could. The embedded views in the parent container were copy/pasted so I added a new embedded view object and pointed it to the Flex View and it is also experiencing this issue.
