Embedded Views Not Loading
I have this massive JSON that I use to generate this screen of parameters. I am using a hamburger to collapse them all initially to ease the loading. Yesterday everything was working fine, but now an issue has arisen. Some times when clicking the hamburger the parameters appear, other times it doesn't, and other times only half of them appear. What could be happening?!
Here is a sample of the JSON:
[{"GroupName":"Main HMI Settings (Non-Recipe Specific)",
"groupParams":{"parameterIDs":[380,381,382,383,384,385,386,387,388,389,390],"inputTypes":["numeric","numeric","numeric","numeric","numeric","numeric","numeric","numeric","numeric","numeric","numeric"],"targetValues":["1","1","12","2","2","2","2",null,null,null,null],"ranges":[{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null},{"lower":null,"upper":null}],"parameterArticles":[null,null,null,null,null,null,null,null,null,null,null],"parameterEnabled":[true,true,true,true,true,true,true,true,true,true,true],"parameterTooltips":[null,null,null,null,null,null,null,null,null,null,null],"parameterNames":["Infeed #1 Open Delay","Infeed #1 Close Delay","Infeed #2 Open Delay","Infeed #2 Close Delay","Outfeed Open Delay","Outfeed Close Delay","Down Bottle","Down Bottle Time","Full Speed Delay","Cycle Stop","Cycle Stop Time"],"isCTQ":[false,false,false,false,false,false,false,false,false,false,false],"parameterUnits":[null,null,null,null,null,null,null,null,null,null,null],"choices":["null","null","null","null","null","null","null","null","null","null","null"]},"isEnabled":true,"LocationID":12,"sheetID":1119,"ScopeID":33,"instancePosition":{},"instanceStyle":{"classes":""}},{"GroupName":"Brushes/Rollers","groupParams":{"parameterIDs":[391,392],"inputTypes":["numeric","numeric"],"targetValues":[null,null],"ranges":[{"lower":null,"upper":null},{"lower":null,"upper":null}],"parameterArticles":[null,null],"parameterEnabled":[true,true],"parameterTooltips":[null,null],"parameterNames":["Color","Brush Format End of Peel"],"isCTQ":[false,false],"parameterUnits":[null,null],"choices":["null","null"]},"isEnabled":true,"LocationID":12,"sheetID":1119,"ScopeID":34,"instancePosition":{},"instanceStyle":{"classes":""}}]
I am using a flex repeater to handle the grouping and in the grouping embedded view another flex repeater to handle the rows of parameters.
The version might be important here
