Hello everyone,
I’m having trouble with a view appearing
I created a scipt allowing me to retrieve the post name according to the folders of my sites
So Script = “PDL” or “PDL PTR 1”
according to this value, I would like to display the view that goes with what is in the “security” folder
(on the second screen)
So I wanted to know if there was a function already defined or how I could do?
Thank you
lrose
April 27, 2022, 3:04pm
2
I’m assuming this is a binding on the props.path.
The path has to be fully qualified, not just the name of the view so the result of your script needs to have the full folder structure included.
Assuming that Securite is a folder under the Views folder then the returned path would need to be
Securite/sec_mul/PDL
or
Securite/sec_mul/PDL PTR 1
Yes, it’s a binding on props.path
I will use as path:
“/Securite”+"/sec_mul"+"/"+Script
But to bring up the view, I have to use a specific function?
lrose
April 27, 2022, 3:25pm
4
No, if the path is valid, so long as it isn’t referencing the parent view, the embedded view should display the view the path points to.
It refers to the good path, but does not views sight…
I am surely making a mistake
I thought he was trying to change the path of an embedded view…
@Valerian_LADIEU
What you’re trying to do is not clear, maybe try explaining in french what your goal is ?
By the way, I sent you a pm the other day. I believe we’re working on the same solar farms !
Its good
I was only using a / at first and it doesn’t have to be
