So I build this overview (See attached) which is a root container and an individual container for each corresponding line.
I built each line on it’s own as zoom screens and they have their own windows outside this main overview … I got things mostly where I wanted and then started clicking around to see what all I could do.
Inside the Root Container there was a check box called enable (set to true) which screamed do not touch so of course I had to click it … everything went gray … makes sense if everything is disabled it’s not going to be working so moving on I clicked enable and nothing happened, clicked it a few times t make sure I was clicking it in the right manner … nothing … panic was starting to set in as it appeared I couldn’t do ANYTHING now as far as animation or control. I was able to click individual images and I noticed they too were not enabled so I enabled one and it started working … then it struck me. I have about 80 objects per container and 8 containers … I better start clicking.
I actually just deleted all the containers and copied them from the other windows but it got me thinking about what if I (or someone I work with) did this in the field.
Is there an easier way out ?
Should it have enabled all when I did that first renable click in the root container ?
Any help would be greatly appreciated.
–Chris
