Enable/Disabling a Gateway Timer script via script
I have a button. When it's enabled I want the timer script to always execute (enable) but if the user press it again I want the script to not run (disable).
Our current solution is something like this:
#timer
active = system.tag.readBlocking(["path/timer_script_1"])  # bool tag
if active[0].value:
    # Do stuff
    print "Hello world!"
And the button toggles the tag.
Could I enable the script in its entirety?
Thanks in advance!
No. What you are doing is currently the recommended practice. (There will be more options in v8.3.)
Thanks pturme l
