Enable HTTPS and Authentication by default in WebDev
Hi all,
WebDev offers the ability to set 'Require HTTPS' and 'Require Authentication' for each endpoint you configure. The default for both these options is set to False, however. Is there a way to set these to True by default? Or even better: is there a way to set them to True by default and remove the ability to change these values in the designer (i.e. it is only possible to change this in the gateway)?
This looks like a candidate for ideas.inductiveautomation.com Gateway Configuration settings
