Enable Roster Management component for Edge Simple Notification
Since the Edge Panel simple alarm notification uses an on-call roster, can you enable the appearance/use of the Vision roster management object in Edge Panel? I suspect it is only enabled by the presence of the Alarm Notification module, which of course Edge will not have.
Correct, the component itself actually resides in the alarm notification module. Unfortunately that means you'd have to basically come up with your own solution for 'live' roster editing in the client on Edge.
Thanks Paul, so be it! Thanks for getting back to me so quickly.
