Enabled modules in container yaml
I am a little stuck on how to activate the event streams module in 8.3 running in kubernetes.
I have this line in my yaml config:
- name: GATEWAY_MODULES_ENABLED
value: "allen-bradley-drivers,vision,perspective,eventstream,mssql,postgresql,bacnet-driver,dnp3-driver,logix-driver,modbus-driver-v2,omron-driver,opc-ua,siemens-drivers,udp-tcp-drivers,web-developer"
( I also want to enable postgresql and mssql and have same problem) - I do not know what name the module has - I tried using the data/api/v1/resources/names/com.inductiveautomation.opcua/device
API from python to list disabled modules (YES; API!!!) , and I get a list, but it seems to not correspond to the expected name in GATEWAY_MODULES_ENABLED
com.inductiveautomation.sfc SFC
com.inductiveautomation.sqlbridge SQL Bridge
com.inductiveautomation.jdbc.mariadb MariaDB JDBC Driver
com.inductiveautomation.eventstream Event Streams
com.inductiveautomation.jdbc.postgresql PostgreSQL JDBC Driver
com.inductiveautomation.sms-notification SMS Notification
com.inductiveautomation.opcua.drivers.mitsubishi Mitsubishi Driver
com.inductiveautomation.opcua.drivers.micro800 Micro800 Driver
com.inductiveautomation.opcua.drivers.siemens-symbolic Siemens S7 Symbolic Driver
com.inductiveautomation.reporting Reporting
com.inductiveautomation.phone-notification Voice Notification
com.inductiveautomation.connectors.kafka Kafka Connector
com.inductiveautomation.symbol-factory Symbol Factory
com.inductiveautomation.alarm-notification Alarm Notification
com.inductiveautomation.jdbc.mssql MSSQL JDBC Driver
com.inductiveautomation.opcua.drivers.iec61850 IEC 61850 Driver
com.inductiveautomation.eam Enterprise Administration
com.inductiveautomation.historian Historian
com.inductiveautomation.historian.sql SQL Historian
com.inductiveautomation.opcua.drivers.dnp3v2 DNP3 Driver
I would of course like to know the names, so I can get unstuck, but I’d also love to know where I can find this myself
I cannot enable the modules from the UI
The reverse DNS name identifiers "should" be used (as far as I know).
@kcollins can probably advise more :smiley:
These are typically what are used for the fully-qualified module ID. If you want to extract the module ID for a given module, you can run the following (on Linux/macOS/WSL2 with unzip and xmlstarlet CLI tools installed):
unzip -c -q /path/to/module.modl module.xml | \
  xmlstarlet sel -t -v "/modules/module/id" ; echo
For example, this shows how to retrieve the module ID from Cirrus Link’s MQTT Transmission Module:
Since Event Streams (and the module-based JDBC drivers) is new with 8.3.0, you must use its fully qualified module ID, com.inductiveautomation.eventstream (as shown in the docs that @paul-griffith linked :folded_hands: ).
Also of note is that these identifiers can also be used with the new ACCEPT_MODULE_LICENSES and ACCEPT_MODULE_CERTS environment variables to apply automated acceptance of the applicable licenses and certificates for third-party modules. No more hackery needed to get a fresh out-of-box Ignition Gateway with third-party modules in a ready and Running state.
I should also mention for others who might be otherwise unaware that with Ignition 8.3, installation of third-party modules within our container image now flow to an area within the data volume. Module enabled/disable status is also persisted there. You no longer need to bake in third-party modules into a derived image to make sure that they’re still there on container lifecycle events.
If you are driving GATEWAY_MODULES_ENABLED, you’ll notice that you cannot enable/disable modules through the web UI. This is by-design, as declaring this variable implies locking in the set of enabled modules. Finally, with the container image, built-in modules (i.e. ones in the image under /usr/local/bin/ignition/user-lib/modules) cannot be uninstalled through the web UI. You might notice that you could do this with the Ignition 8.1.x container image, but the modules would magically re-appear if you recreated the container.
I am spinning up an 8.3.2 version of maker using
But I still get modules that are not listed and marked as error “Not eligible for use with Ignition Maker Edition“
Any idea why or is this a bug?
Modules showing up that I don’t have in enabled:
  • Kafka Connector
  • Omron Driver
  • Logix Driver
  • Siemens Drivers
  • Mitsubishi Driver
  • Micro800 Driver
  • Allen-Bradley Driver
What I have Specified in my Gateway modules enabled:
  • com.inductiveautomation.connectors.mongodb
  • com.inductiveautomation.jdbc.postgresql
  • com.inductiveautomation.jdbc.mariadb
  • com.inductiveautomation.jdbc.mssql
  • com.inductiveautomation.eventstream
  • com.inductiveautomation.alarm-notification
  • com.inductiveautomation.opcua
  • com.inductiveautomation.perspective
  • com.inductiveautomation.reporting
  • com.inductiveautomation.sfc
  • com.inductiveautomation.sqlbridge
  • com.inductiveautomation.historian
  • com.inductiveautomation.historian.sql
  • com.inductiveautomation.webdev
  • com.inductiveautomation.opcua.drivers.tcpudp
  • com.inductiveautomation.opcua.drivers.modbus
This behavior surprised me, but it looks like we do have a ticket in our system for this, IGN-14320. Thankfully, it looks like if you just omit GATEWAY_MODULES_ENABLED env var, things work correctly. With 8.3.x, you don't need this variable to persist module enable/disable state.
Thanks! I had that in there from 8.1, i just removed it and it works fine.
