Engineering Units from OPC
Hello all! I'm wondering how best to get custom engineering units from OPC. Our OPC server provides UCUM engineering units and there doesn't seem to be a simple way to link this when I create a new OPC tag. For instance, one of the nodes we have provides a value (double) and Engineering units, of which the value is in degrees:
Value EUInformation [NamespaceUri="ucum.org", UnitId="0", DisplayName="deg", Description="deg"]
How could I script / link this so that the tag has the information?
Thanks,
Ethan
I would make a script that takes a tag path as a parameter and uses system.opc.readValue | Ignition User Manual to grab the EU and add it to a tag using system.tag.configure | Ignition User Manual and have a gateway event that runs this script as needed for each tag that is able to provide this data.
