Was working on tag even scripts this morning and all of a sudden the folder with all the tags became completely inaccessible showing as and error icon in the tag browser. Every other tag works except for tags inside this specific folder. Pretty much an entire morning worth of work down the drain. Restarting the gateway solves nothing. No errors on the gateway log, but this error in the designer.
10:54:30.627 [Tags-TreeLoader-1] ERROR com.inductiveautomation.ignition.client.tags.tree.node.FolderNode - Error loading tags underneath [default]KPI/TP11/Charts
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to read response from Gateway.
at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.ignition.client.tags.tree.node.TagTreeNode.executeChildrenBrowse(TagTreeNode.java:134)
at com.inductiveautomation.ignition.client.tags.tree.node.AbstractBrowseNode$Loader.doRun(AbstractBrowseNode.java:511)
at com.inductiveautomation.ignition.client.tags.tree.node.AbstractBrowseNode$Loader.run(AbstractBrowseNode.java:551)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to read response from Gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:457)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:917)
at com.inductiveautomation.ignition.client.tags.impl.GatewayTagInterface$GatewayProviderProxy.browseAsync(GatewayTagInterface.java:281)
