Entra ID Azure and SAML IdP Ignition
Hello,
I am trying to setup SAML 2.0 IdP on the Ignition side for a client, the client are the ones configuring the Entra ID side.
The test login almost looks like it goes through, I get redirected to the microsoft login page and login with the domain account, but then I get "No IdP Response Data" once the login goes through.
I couldn't find much documentation about how to set this up with specifically Entra ID and SAML but essentially, I uploaded the client's XML and sent mine after, all the fields on the IdP are filled so I feel like I'm missing something.
Are there any common problems or things people often forget to setup for this kind of Identity Provider? Do you need to also setup a user source?
Thank you!
Hey J-P, we have a similar problem now when trying to use Entra ID Azure with SAML. We receive the "No IdP Response Data" and when checking the logs, is seems that there might be a problem with the audience. We were thinking that it might be a configuration issue on the Entra ID side, but we couldn't yet figure out what it is.
Did you end up get this working? Thanks
