EnumField Example
Does anyone have an example of how to use the following to make a drop down options list on a settings page?
EnumField
Thanks,
Nick
Answering my own question here and hopefully helping someone down the line, here is how to do it:
1) In the Settings File Create an enum
public enum alarmPriorities { Diagnostic, Low, Medium, High, Critical };
2) Create a EnumField
    public static final EnumField<alarmPriorities> MinimumPriority =
            new EnumField<>(META, "MinimumPriority", alarmPriorities.class, SFieldFlags.SMANDATORY).
                    setDefault(alarmPriorities.Medium);
I still need to make more access methods so the field value is actually used for filtering, but for testing I just made a simple method that sets the default value so the module could install without error:
3) Create necessary access methods
public void setDefaultAlarmPriority() { setEnum(MinimumPriority, alarmPriorities.Medium); }
Then when the module is installed it looks like this:
I’ll post the access methods later on.
Nick
Here are two additional access methods that were made:
The first is to get the string value
    public String getAlarmPriorityString() {
        return getEnum(MinimumPriority).toString();
The second is to get the integer value of the string index from the enum. This is needed because the alarm priority which will be filtered against is an integer 0-4.
Get the index value as an integer
    public int getAlarmPriorityInt() {
        return alarmPriorities.valueOf(
        ).ordinal();
Then the integer value is used like this on the alarm event action
int minimumPriority = kafkaSettings.getAlarmPriorityInt();
Boolean hasPriority = alarm.getPriority().ordinal() >= minimumPriority;
Rgds,
Nick
